Sign in to follow this
Alexandra Gonzalez
problems with remote operation
Hi,
Using Remote Operator. I'am connecting to a USC-B10-R38  via LAN.
TCP settings, PLC name, port nr are all correct.
I use Unit ID 0 (direct)
"cannot communicate with the PLC with specified UnitID!"
Any ideas?
I can connect to it via Remote Access with the same settings. I run the application as administration and it doesn't work :(
Also, do i need any expansion to connect this way?
This model of PLC does not support either Remote Access or Remote Operator.
USC PLC is a UniStream PLC with Virtual HMI.
To use Virtual HMI, you can use UniStream Display USL-050-B05 (5") or USL-050-B05 (7").
Or UniStream HMI Panels, or any other device supporting VNC Client - Tablet, PC, etc.
B.R.
17 hours ago, Alexandra Gonzalez said:
It did work in the past but now gives me:
So.......when it previously worked was it exactly the same PLC model as now?
cheers, Aus
