bjarni Posted August 13, 2019 Report Share Posted August 13, 2019 Hello, I'm just starting my first project with UniStream/UniLogic and I have the PLC hooked to a PC via Modbus, PLC as Slave. I haven't found a way to sync the clock in PLC with the PC clock. Is there a way to set the PLC clock via the Modbus ? Thanks, Bjarni Quote Link to comment Share on other sites More sharing options...
NoamM Posted August 14, 2019 Report Share Posted August 14, 2019 Hi bjarni, You can use the "Set PLC Time" and "Set PLC Date" Ladder functions. Trigger them via Modbus. Quote Link to comment Share on other sites More sharing options...
bjarni Posted August 14, 2019 Author Report Share Posted August 14, 2019 So easy . Thanks a lot. Quote Link to comment Share on other sites More sharing options...
