AlexsandrIgorevich Posted August 16, 2019 Report Share Posted August 16, 2019 I apologize for the primitive questions. I just started my acquaintance with Visilogic. There are two examples in the Vector: Store help section (register and bit operation). It says that a bit operation overwrites operand A, and a register operation overwrites a memory location equal to A plus offset B. Is this really true or is there an inaccuracy in the help? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted August 16, 2019 MVP 2023 Report Share Posted August 16, 2019 Moved to the correct forum. It looks like the help file could be a little more clear, but the bottom line is that the Vector: Store function always overwrites the register or bit at the location A+B. It will only overwrite A if B=0. Quote Link to comment Share on other sites More sharing options...
