ORSO2001 Posted August 21, 2019 Report Share Posted August 21, 2019 Dears, In the help file I saw that I can use an action event to play a video...I don't found the "play video" trigger command...what I am missing? just to be clear...I also create a screen with the "video widget" but is the same. thanks Quote Link to comment Share on other sites More sharing options...
AlexUT Posted August 21, 2019 Report Share Posted August 21, 2019 Hi, 1. Add new display. 2. Create Media applet at selected display. 3. In applet properties select media type. If Autoplay enable - activate display will start video play. Quote Link to comment Share on other sites More sharing options...
Saragani Posted August 21, 2019 Report Share Posted August 21, 2019 The help section about the play video was probably created during Beta developments. This feature has been deprecated, since you can control the video directly from the screen. Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted August 21, 2019 Author Report Share Posted August 21, 2019 ok...clear...thanks Quote Link to comment Share on other sites More sharing options...
