Davenj Posted August 23, 2019 Report Share Posted August 23, 2019 We sell systems that are installed on trucks for fueling (12v or 24v). At the end of each transaction the customer wants a text message of fuel dispensed, date, time, GPS location, etc. Any suggestions on Modem kit, GPS unit, or anything else would be appreciated. Quote Link to comment Share on other sites More sharing options...
DanT Posted August 27, 2019 Report Share Posted August 27, 2019 Hi Dave; There is a Modem Kit for the Vision Series GSM-Kit-17J-3G -- contact your distributor. This has the cables required and is supported in VisiLogic - see Modems and Help for the setting up. The SIM Card is the customer's responsibility. This uses a Serial Port. I have used a Garmin GPS unit. - Also Uses a Serial Port. The V130 has 1 Serial Port, so you have to add a 2nd serial port ( Then NO Ethernet can be added ) This means programming and working with 2 used serial ports will be fun. Suggestion : GPS in Port 1 and have a menu in the PLC where you can select to program or use the GPS. When Working with the GPS getting all the data strings sorted out, put the GPS in Port 2 until you have it working properly and then move it over to Port 1 and use the menu to change between GPS and Programming Modes. Then work on the Modem to get it setup in Port 2 and leave it there. DanT Quote Link to comment Share on other sites More sharing options...
Davenj Posted August 27, 2019 Author Report Share Posted August 27, 2019 Thanks DanT, allot of testing in my future I think. Quote Link to comment Share on other sites More sharing options...
