bjarni Posted September 6, 2019 Report Share Posted September 6, 2019 Hello, I have an Unistream panel and EX-RC1+ D16A3-RO16 + LC3 units hooked to it via CAN bus. I have to read position from an encoder (with A, B and Zero inputs) and wonder if someone here would give me an suggestion regarding hardware for the job? Should I just add an IO unit (and which one) or could I replace the D16A3 unit with another which also supports encoder readings? Thanks, Bjarni Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted September 6, 2019 MVP 2023 Report Share Posted September 6, 2019 I thought the D16A3 could already do what you want. Quote from Install Guide: <<<< Inputs 4 and 6 can function as high-speed counters, frequency measurers, or general purpose digital inputs (set in software). Inputs 5 and 7 can function either as counter reset inputs or general purpose digital inputs (set in software). >>>> If you are wanting to keep up with this read in "real time", you might run into issues due to the delays using the EX-RC1 via a bus. cheers, Aus Quote Link to comment Share on other sites More sharing options...
bjarni Posted September 6, 2019 Author Report Share Posted September 6, 2019 27 minutes ago, Ausman said: I thought the D16A3 could already do what you want. Quote from Install Guide: <<<< Inputs 4 and 6 can function as high-speed counters, frequency measurers, or general purpose digital inputs (set in software). Inputs 5 and 7 can function either as counter reset inputs or general purpose digital inputs (set in software). >>>> If you are wanting to keep up with this read in "real time", you might run into issues due to the delays using the EX-RC1 via a bus. cheers, Aus Yes, but encoder isn't just a counter. I need to stop/start motor at different positions at predetermined but variable degrees and I believe that I read somewhere (maybe these forums) that fast counter isn't enough. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted September 6, 2019 MVP 2023 Report Share Posted September 6, 2019 Hi Bjarni, happy to stand corrected if needed. Someone who really knows should chime in soon, and can whack me around the head with a foam bat as necessary. I don't routinely work with encoders, so have maybe missed something crucial. For better info, what is the brand/model of the encoder? cheers, Aus Quote Link to comment Share on other sites More sharing options...
bjarni Posted September 6, 2019 Author Report Share Posted September 6, 2019 Hi Aus, Encoder is TURCK RI-12H14T-2B4096-H1181 Thanks, Bjarni Quote Link to comment Share on other sites More sharing options...
DanT Posted September 6, 2019 Report Share Posted September 6, 2019 Hi; The IO-D16A3-RO16 High Speed Inputs cannot do quadrature encoder inputs. The proper High Speed module for UniStream is the UID-0808THS . There are several "scenarios" to choose from to work with encoders and High Speed Outputs An alternate is the new Ethernet IO Modules -URB-TCP + URD-0200D ( 5V Encoders) or URD-0200E (24 VDC Encoders) Read the URP Manual -- These are expensive Note that the EX-RC1 may do the Loadcell Functions, BUT, the EX-RC1 does NOT have any Battery Backup! You may have to use POWER Up Values once you have the setup values defined properly. DanT Quote Link to comment Share on other sites More sharing options...
bjarni Posted September 6, 2019 Author Report Share Posted September 6, 2019 Thanks DanT, I'll have one unit shipped to me... Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted September 6, 2019 MVP 2023 Report Share Posted September 6, 2019 Thanks Dan, I stand head whacked. cheers, Aus Quote Link to comment Share on other sites More sharing options...
DanT Posted September 10, 2019 Report Share Posted September 10, 2019 Hi; 1 further note: The UID-0808THS accepts only the A and B Signals from the encoder. The Z output can be used on another High Speed input, and then dealt with in the program. DanT Quote Link to comment Share on other sites More sharing options...
bjarni Posted September 10, 2019 Author Report Share Posted September 10, 2019 👍 I'll keep it in mind, Thanks Quote Link to comment Share on other sites More sharing options...
