Sign in to follow this
Simon
Printing from U90 Ladder
Has anyone had trouble printing from U90 Ladder?  It isn't something I do very often, but I wrote a little program for a customer and wanted to print out some key sections.  I tried printing to 3 different PDF printers, as well as the office hardcopy printer.  I also tried printing via the Print Preview screen.  When I hit print it sits there for about 20 seconds, then appears to print something but nothing happens.  In the case of PDF print I get no dialo box to enter a filename, for physical printer, there is no printout.
Using U90 Ladder 6.6.45 and have run the patch on my PC to fix the recent issue with Windows updates.
At this stage it's not a crticial issue but I would be interested to know if anyone else has experienced this, and if there is a simple fix.
Thanks,
Hi Simon, 6.6.45 on W7 64 Pro with all recent updates done, seems ok to all printer types.  Various print previews worked fine as well.
Have you tried a really truly ruly uninstall?
cheers, Aus
