ORSO2001 Posted September 16, 2019 Report Share Posted September 16, 2019 Dears, I am using PID functions...and I thik to have learned how this works but I don't found a way to "stop/reset" the autotune procedure when active!?...i try to explain what i need...I am talking about a management of heating element...if I start the autotune (PID config status = 2) and the real temperature is not increasing (heating element broken or not connected) what I have to do to stop the autotune to have back its status as "0"?...I tried to set "0" the BIT to enable the Autotune UDFB but the status stay at 2...I have wait many minutes with the BIT "1" without increasement of the temperarute...also with the BIT as "0" but nothing happened....now that I am writing I thought..."this is not a problem...will be enough "load" again the AT values!"...what is the right way? thanks. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted September 16, 2019 MVP 2023 Report Share Posted September 16, 2019 Try re-activating the PID Configuration FB. Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted September 18, 2019 Author Report Share Posted September 18, 2019 hi Flex, thanks for the answer...I realized that a "reset PID Autotune" function is enough...😁 Quote Link to comment Share on other sites More sharing options...
