NewMember_R Posted September 25, 2019 Report Share Posted September 25, 2019 Hallo, I m new in using PLC von unitronics.I want to use the advanced Webserver on my Vison 350. I did every step on the intruction but i cant figured out what i did wrong because it doesnt work . I m using the template file and i just change the IP adress .If i set the socet init to TCP/IP I can use the Remote acces normaly.But if i change it to HTML on port 80 so that i can use the webserver , nothing works. did someone have an idea whats wrong hear Quote Link to comment Share on other sites More sharing options...
