DanA Posted September 26, 2019 Report Share Posted September 26, 2019 Hi, I am new with Unilogic and would learn how to setup/program the Stepper Motor AMP ST24IP with unistream 10.4 Controller. I am using Unistream 10.4 Controller connecting to the Motor via UID-0808THS. Does anyone have a simple program to setup and send data to motor, just to spin up that stepper motor with inputs for changing Speed and Distance? I am open to use whatever method that works with the AMP stepper motor. Thanks, Dan Quote Link to comment Share on other sites More sharing options...
DanT Posted September 27, 2019 Report Share Posted September 27, 2019 Hi; Have you downloaded the zip file with UniStream Sample programs? -- Just under the UniStream Download. There are a large number of example programs done by topic. There are a couple of sample programs using the UID-0808THS in there to examine and help you get going. As Joe Tauser and others re-iterates often here : Take a crack at it and create your own code and then we can help you along. Dant Quote Link to comment Share on other sites More sharing options...
DanA Posted September 27, 2019 Author Report Share Posted September 27, 2019 Yes, I have, but not much info on communicate to Stepper Motor with Unilogic. Attached please find a short program I have. I could not get the AMP Motor to spin up with it.. The program is just to get Motor spinning up when pressing "START" Motor_Test.ulpr Quote Link to comment Share on other sites More sharing options...
