golzione Posted September 30, 2019 Report Share Posted September 30, 2019 Hi All, I'm using a VT570 to log some data to SD card. I realized a single Trend with 2 curve for 2 sensor. My goal is to log on a monthly basis this data on a file. File name is "MMYY.utr". Sample rate is 1 data every 5 minutes. When I export data from SD to Excel using the appropriate tool I always have DateTime column rollback in a strange way. All the datetime are correct till to 25th of month and then they are wrong (even if the logged data continues to be correct). Here under you can find some screenshots that I hope explain the issue better than my words. Ladder code is simply and It is essentially a copy of Visilogic example to save Trend on SD Card but I'm not able to understand where is the error. Any help or advise will be very appreciated. Regards Golzione Quote Link to comment Share on other sites More sharing options...
golzione Posted October 1, 2019 Author Report Share Posted October 1, 2019 Hi All, I made just now another trial and I realize that the issue It is always after 7160 Samples (please look at excel screenshot) The sample number 7161 has the wrong timestamp (even if trend visualization is correct). All the best Golzione Quote Link to comment Share on other sites More sharing options...
golzione Posted October 3, 2019 Author Report Share Posted October 3, 2019 Hi, Is there something or debug in memory to understand what's going on on Trend memory inside PLC after 7160 samples? All the best Golzione Quote Link to comment Share on other sites More sharing options...
AlexUT Posted October 3, 2019 Report Share Posted October 3, 2019 Hi golzione, You are going very deep at user level. please send your project to Unitronics Technical Support for review. *Add PLC serial number for reference. *Is the PLC battery voltage OK? What is a SB 8 status? *Does PLC show right time/date? time Then we will run it at our desk for simulation and will show result to R&D if we find a problem. Until now you are the first who comply for such trend behavior. B. R. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted October 3, 2019 MVP 2023 Report Share Posted October 3, 2019 HI golzione, I just noticed this for the first time. This possibly may have something to do with the way you are handling the data. To me it looks like you are not clearing your data table each time it needs to restart from Row 1. What happens then is that the old row gets overwritten with the new information. In your case you have the data stored on the 7/7 over-written on the 25/8, and the data looks correct because it is simply a continuing record of your process. I routinely log stuff on a one minute/ 24 hourly basis, and set up my data tables accordingly so that I don't have to clear them. The next lot of 24 hours records over-writes the current rows right up to the last row of the table, and then the row counter is reset to 1 at midnight and things start again. At 11:59:10 PM the data table is copied to the SD so that it is permanently logged under that day's date. The difference here may be that you are writing direct, but the fundamentals of what I am describing may still be occurring. cheers, Aus Quote Link to comment Share on other sites More sharing options...
golzione Posted October 4, 2019 Author Report Share Posted October 4, 2019 Hi all, first of all thank your time. On 10/3/2019 at 12:11 PM, AlexUT said: Hi golzione, You are going very deep at user level. please send your project to Unitronics Technical Support for review. *Add PLC serial number for reference. *Is the PLC battery voltage OK? What is a SB 8 status? *Does PLC show right time/date? time Then we will run it at our desk for simulation and will show result to R&D if we find a problem. Until now you are the first who comply for such trend behavior. B. R. Is It possible to get PLC serial Number from remote? Battery Voltage is OK and SB 8 status is always equal to 0 PLC show Date/time correctly. Which is the email to send my project to Unitronics Technical Support? On 10/3/2019 at 11:52 PM, Ausman said: HI golzione, I just noticed this for the first time. This possibly may have something to do with the way you are handling the data. To me it looks like you are not clearing your data table each time it needs to restart from Row 1. What happens then is that the old row gets overwritten with the new information. In your case you have the data stored on the 7/7 over-written on the 25/8, and the data looks correct because it is simply a continuing record of your process. I routinely log stuff on a one minute/ 24 hourly basis, and set up my data tables accordingly so that I don't have to clear them. The next lot of 24 hours records over-writes the current rows right up to the last row of the table, and then the row counter is reset to 1 at midnight and things start again. At 11:59:10 PM the data table is copied to the SD so that it is permanently logged under that day's date. The difference here may be that you are writing direct, but the fundamentals of what I am describing may still be occurring. cheers, Aus I got your point but I don't think It is occurring here. The data stored on 25/8 are correct. I mean only timestamp is not not correct. I check the value on 7/7 and they are very different. I put here only 1 example but this behavior happen every month. Luckily sensors values are correct (there is any discontinuity) so It is simple to fix excel file but in any case It is annoying and I hate where I cannot understand whats going on my sw. Regards Golzione Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted October 5, 2019 MVP 2023 Report Share Posted October 5, 2019 You might want to try what I describe in this post: http://forum.unitronics.com/topic/4342-win-7-and-others-update-quirk-affecting-excel/ I had really weird time behaviour and my cure fixed it. It's a long shot, but maybe it isn't Unitronics related at all. cheers, Aus Quote Link to comment Share on other sites More sharing options...
golzione Posted October 5, 2019 Author Report Share Posted October 5, 2019 Thanks Aus, I will give It a try All the Best Golzione Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted October 5, 2019 MVP 2023 Report Share Posted October 5, 2019 If it possible please explain MB38. MB1 has different action. Quote Link to comment Share on other sites More sharing options...
golzione Posted November 27, 2019 Author Report Share Posted November 27, 2019 Hi All, I'm sorry if I'm not update this thread for a long time but I was very very busy. That MB38 bit rise up on every month change and in this way after the name of the file saved to SD card is changed I stop saving trend on SD and then start again with the new file name when that bit falls down. Regards Golzione Quote Link to comment Share on other sites More sharing options...
golzione Posted November 27, 2019 Author Report Share Posted November 27, 2019 Hi All, my last month trial was to change the Sampling Rate to 1 data every 10 minutes (the old one was 5 minutes). Now I Have the same issue after 3580 samples. Please let me know how to send my project to Unitronics Technical Support for review. All the best Golzione Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted November 28, 2019 MVP 2023 Report Share Posted November 28, 2019 Click on Support at the top of the page, and submit a ticket. Or send it direct to support@unitronics.com cheers, Aus Quote Link to comment Share on other sites More sharing options...
golzione Posted November 29, 2019 Author Report Share Posted November 29, 2019 On 11/28/2019 at 3:41 AM, Ausman said: Click on Support at the top of the page, and submit a ticket. Or send it direct to support@unitronics.com cheers, Aus Thanks, I send a mail to the support team yesterday with my project attached. Regards Golzione Quote Link to comment Share on other sites More sharing options...
