Samith Chathuranga Posted September 30, 2019 Report Share Posted September 30, 2019 Hi, I'm new to Unitronics PLCs. I bought up Unistream 5" pro HMI+PLC. My project is connecting 48 photo sensor inputs into the PLC & that should be monitor using Node-Red dashboard. I hope to use mosquitto as broker connection in separate PC. I bought TP Link router also to connect PLC. How can I setup my sensor inputs as subscribers to mosquitto broker in PLC ? Please help Quote Link to comment Share on other sites More sharing options...
NoamM Posted October 16, 2019 Report Share Posted October 16, 2019 Dear Samith Chathuranga, From the PLC POV you need to configure the mosquitto broker connection parameter in UniLogic. From the Help section: 2 Quote Link to comment Share on other sites More sharing options...
Samith Chathuranga Posted October 21, 2019 Author Report Share Posted October 21, 2019 Hi NoamM, successfully I could able to configure local mosqutto broker. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
