Magnus k Posted October 2, 2019 Report Share Posted October 2, 2019 Hey there folkz. I have a test station here that i prep for 2021. Im not to well used for plc progamming so i hope i can get my answers here. The task is to make A program to be created in sequence with a percentage increase in air pressure in the tank, with fixed consumption. The working area of the tank is 0-5bar The sequence is as follows: Tank pressure increases to 25% The pressure is kept stable for 1 min Tank increases to 50% held for 1 min Tank increases to 75% held for 1 min Tank drops to 25% and the sequence is reatarted. i understand that pid is involved in one ladder by it self, so my question is how do i implement the values into a sequance cheers Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted October 2, 2019 MVP 2023 Report Share Posted October 2, 2019 Take a look at this post- Download a look at the program I attached called Jazz Stage Example. This should help you start to form your sequence - you'll be stepping through a timer-based sequence where you move different setpoints to your PID block. How are you controlling the air pressure? Start your program and then post it here with questions you have. Joe T. Quote Link to comment Share on other sites More sharing options...
Magnus k Posted October 3, 2019 Author Report Share Posted October 3, 2019 Hi Joe Thank you for the reply, the air pressure is pumped up by a frequency driver and a motor pump which the pressure is adjusted by this Samson 6111 i/p converter. the pressure then goes to the valve which controls the flow of air. I made a drawing in the attachment. The air pressure in the tank is monitored/read by a normal pressure transmitter where the PLC takes on the PID section. as ive come to understand i may have to use the linerzation block for the analog input and then make use of the timers. still working with a solution. cheers Magnus Quote Link to comment Share on other sites More sharing options...
