Glenn Posted October 2, 2019 Report Share Posted October 2, 2019 Has anyone managed to get the enhanced webserver running on a V1040? I have had success using the simple webserver. This works fine both locally and remotely, so port forwarding is operational. I would like to use the enhanced webserver ( using HTML). I downloaded the sample to my V1040 , and compiled the start.html ( as directed from webinar), and stored it on my SDCard. When I go to browser and type in IP ( local or remote) the website never appears.. Seems okay when I run the preview in Brackets. Any thoughts/suggestions? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted October 2, 2019 MVP 2023 Report Share Posted October 2, 2019 I don't use this feature so I may not be of much help, however, did you check the basics? Has the SD card been formatted with the Unitronics SD card utility? Is SB 217 turned on with the SD card inserted? Is the html file in the correct folder? Also, what capacity is the SD card? Quote Link to comment Share on other sites More sharing options...
AlexUT Posted October 3, 2019 Report Share Posted October 3, 2019 After downloading Complex WebServer from "PLC Tools & Applications" and unzipping it to separate directory, read "Enhanced PLC WebServer.pdf" document. *Write project Data Table information to PLC to make Web Server working. 1 Quote Link to comment Share on other sites More sharing options...
Glenn Posted October 16, 2019 Author Report Share Posted October 16, 2019 Flex 727 - SD Card is formatted and is successfully logging additional tables every minute. SD card is 14.4GB SB217 is 1 when card is installed HTML is stored in Web folder as advised Quote Link to comment Share on other sites More sharing options...
Glenn Posted November 4, 2019 Author Report Share Posted November 4, 2019 Okay thanks Alex; I'll look into this when I get more time. I've got 6 systems in the field and also want to look at adding in a data historian server for data analysis. Quote Link to comment Share on other sites More sharing options...
