jonttez Posted October 9, 2019 Report Share Posted October 9, 2019 Hi! I'm facing a problem while using Accelerate FB with Samba Os 4.6.20 When I use accelerate fb on my project, my controller crashes and opens a black screen with fatal error - message I tested it with an empty project with just an accelerate fb and it still crashes, is there a bug or am i just doing something wrong My program works as it should when I use Os 4.6.19 on my controller, but unfortunately my project requires os 4.6.20 Quote Link to comment Share on other sites More sharing options...
AlexUT Posted October 10, 2019 Report Share Posted October 10, 2019 Hi, Which version of software are you working with? Please ensure you are using 9.8.80, and then go to Help > Check for updates > Operating System. Then please update the controller's OS. There was an issue with the acceleration function block in previous versions. 1 Quote Link to comment Share on other sites More sharing options...
jonttez Posted October 15, 2019 Author Report Share Posted October 15, 2019 Hi! And thank you for replying! I'm working with 9.8.80 and have tried updating the controller's OS. My local Unitronics representative was able to confirm this bug with controller's OS 4.6.20 and Unitronics is currently working on the problem. Quote Link to comment Share on other sites More sharing options...
