Fahrphrompuken Posted October 11, 2019 Report Share Posted October 11, 2019 Hi- I am using ver. 1.25.61 Unilogic and cannot find a way to successfully compile if I create a trend graph that is less than 380 x 500. Is there a way to override the compile error, or is there a trick to making a smaller trend graph area? I have never had an issue with this in Visilogic. Quote Link to comment Share on other sites More sharing options...
Saragani Posted October 13, 2019 Report Share Posted October 13, 2019 The minimum size was reduced to 500x300 in 1.28 Quote Link to comment Share on other sites More sharing options...
