Joe Joshi Posted October 12, 2019 Report Share Posted October 12, 2019 Hello, I am trying to convert .usmp file into excel I have downloaded the Unistream data converter suite. For some reason whenever I try to convert .usmp file it gives me the following error "Could not load file or assembly 'Syncfusion.Compression.Base, Version=15.3400.0.26, Culture = neutral, PublicKey =3d67ed1f87d44c89' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)" Any help would be very helpful. Also I have tried download different version of the Unistream data Converters Suite,. Thanks in advance Quote Link to comment Share on other sites More sharing options...
Saragani Posted October 13, 2019 Report Share Posted October 13, 2019 I'll look into it. It looks like there is a conflict with 2 versions of the same dll (Which will need to recompile a new version of the Data Converter suite) Quote Link to comment Share on other sites More sharing options...
Saragani Posted October 16, 2019 Report Share Posted October 16, 2019 I've compiled a new version of the Data Converters Suite, and it should solve the problem. 1 Quote Link to comment Share on other sites More sharing options...
