Load string tag from C-function?
bjarni
Hello, I've been trying to load a string from a c-function - without luck.  Made few approaches though.
One example here:
char arr[3][32] =
{ "String 1",
  "String 2",
  "String 3"
// User code ends above this comment
static void getString(unsigned short Index, volatile char* TheString, int TheStringLen)
    // User code starts below this comment
           TheString =arr[Index];
TheString defined as here:
Is there a way to do it?
Thanks, Bjarni
