Sandy Posted October 22, 2019 Report Share Posted October 22, 2019 Hi, Is it possible to do safe remove of aUSB Stick/DOK from the ladder or a UI element? I'm saving a data row to SD, then the copying it to a DOK, all of which can be done from the ladder, using the status codes to avoid timing issues. I'd like to avoid the "DOK Unsafe Remove" warning that appears. I always get the same warning after using the safe remove button on a File Browser UI element, so this isn't a suitable workaround. Sandy Quote Link to comment Share on other sites More sharing options...
Saragani Posted October 23, 2019 Report Share Posted October 23, 2019 There is a global action for that, so you can set a bit in ladder, and then the global action which is linked to that bit will detect that the bit is 1, reset it, and safely remove the DOK. Quote Link to comment Share on other sites More sharing options...
Sandy Posted October 23, 2019 Author Report Share Posted October 23, 2019 Thank you! Quote Link to comment Share on other sites More sharing options...
