TozoM8 Posted October 29, 2019 Report Share Posted October 29, 2019 I am trying to log the data table from the plc. I've set the port (Ethernet) and set up the site. When I click run, I have the call succeeded status, but I also have a window pop up run-time error'429' ActiveX component can't create object. When I click OK, DataXport closes. what an I doing wrong? Quote Link to comment Share on other sites More sharing options...
Cam Posted October 30, 2019 Report Share Posted October 30, 2019 Are you trying to create an xls, xlsx or csv file from dataexport of the logged data? if so do you have Excel installed on the PC? Quote Link to comment Share on other sites More sharing options...
TozoM8 Posted October 30, 2019 Author Report Share Posted October 30, 2019 I've tried it on another computer and it works now. It saves on schedule or when I manually request, but does not send out the email. Is there a setting how often it sends out? Quote Link to comment Share on other sites More sharing options...
