TozoM8
My newest struggle. Remote Mobil app.
PLC IP 192.168.001.002
port 20256
connected to my NetLINE 10/100 switch
my pc is connected to the same switch and connects to the plc with no problem.
When I use the remote app on iphone
IP 192.168.1.2
port 20256
PLC name set correctly. Why is it not connecting. My phone is connected to my home WiFi.
Not all Vision PLCs work with the Remote App.  This info is squirreled away in the literature.  Check that yours is in the list.
If yours should work,  is the plc on your home network as well?  Sometimes wifi to physical LAN needs a bit of work in the router.  If it is trying to get into your network from WAN, then you will have to do appropriate port directing in the router as well.
cheers, Aus
You don't have your PC connected while you're trying to connect the the remote app, do you?  Only one connection to a port at a time.
You could also try port 20257 on your phone, which is the default port number for Socket 3.
I don't have anything connected to it at the same time. I have all 4 sockets initialized so I can try to connect on different ports. I had it working like two years ago and all I remember that it took me forever to get connected (which doesn't reflect the difficulty level by any means) and it disconnected as soon as I left my WiFi range.
 check that you home WiFi router uses the same subnet for the LAN ports and WiFi.   A different subnet with no route between them can cause your problem.
is the PC a wired or wireless connection.If it’s a wired connection change it to a wireless connection if possible and see if it will still connect
