U90 Posted November 8, 2019 Report Share Posted November 8, 2019 Any ideas how to make a manual uninstall of U90Ladder, as it seems that the usual way does not work. It looks like I have an uncomplete installation blocking. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted November 8, 2019 MVP 2023 Report Share Posted November 8, 2019 Use Revo Uninstaller Portable, let it do an in depth search as well. After that finishes, reboot and check if the "Unitronics U90 Ladder" folder still exists in Program Files (x86), and delete it if it does. Reboot and then install using right click, run as admin. If this doesn't resolve the issue, go through the above uninstall steps again with Revo etc. Once everything is again removed, do a registry clean with the likes of CCleaner, reboot and start again. At all installation attempts, always use right click/run as admin. After a successful install, ensure that the U90Ladder.exe is set to Run as Admin in compatibility settings. cheers, Aus Quote Link to comment Share on other sites More sharing options...
