Rachade Posted November 14, 2019 Report Share Posted November 14, 2019 I want to delete a file on SD card by using an indirect value saved on MI 1500. The file name is 1.CSV how am i suppose to do that ? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted November 14, 2019 MVP 2023 Report Share Posted November 14, 2019 Did you try using the SD Utility: Delete SD File? Quote Link to comment Share on other sites More sharing options...
