Sign in to follow this
Jerin
V350 Error not uploading plcimages
Did you install  8.80 using Right click Run as Admin, and also check that Visilogic.exe is Run as Admin as well once installed?
Have you looked at the Pinned topic:
http://forum.unitronics.com/topic/6069-vision-bricked-issues-and-how-to-resolve-originally-was-v570-57-t20b-j-bricked/
What are you using to communicate with the serial port?  If it is a usb adapter, some don't work properly for the entire O/S update.
cheers, Aus
