Bruce52
UnCmDrv1.dll
I'm wondering if there is any documentation describing all the function calls available in the dll. I looked over the PCOM protocol pdf, but the calls there don't seem to match those used in the VB6 example.
You can find it in http://www.unitronics.com/support/downloads
Go to the bottom of the page. It is under "ActiveX Communication Driver"
Mmmmmhhh.... probably there is something I cannot understand...
In the domload section I can read
This zip file contains an ActiveX .dll file that can be used to implement SCADA. UnCmDrv1.dll file contains methods and properties for invoking the PLC, read / write, locally or remotely, implementation examples, and an explanation of accessing Data Tables.
But if I download the file (rar), the compressed file there is only a single dll, without examples, without explanation... impossibile to use...
Probabily I missed something... Can you please give me the correct link, the one with the example?
