HPE Posted December 2, 2019 Report Share Posted December 2, 2019 We use V570 to read and store pressure data real time. We are using DataXport to poll the V570 every minute and write csv -file of the recorded pressures . The V570 has 49 recipes for different criterias how the pressure should be recorded. The issue is that operators must open DataXport project and then edit table & point to the right recipe each time we want to log data. I am wondering if somebody could write us a datalogger software that would read & store test results directly from V570 thus eliminating the need for DataXport alltogether? Quote Link to comment Share on other sites More sharing options...
Jerin Posted December 20, 2019 Report Share Posted December 20, 2019 On 12/3/2019 at 1:34 AM, HPE said: We use V570 to read and store pressure data real time. We are using DataXport to poll the V570 every minute and write csv -file of the recorded pressures . The V570 has 49 recipes for different criterias how the pressure should be recorded. The issue is that operators must open DataXport project and then edit table & point to the right recipe each time we want to log data. I am wondering if somebody could write us a datalogger software that would read & store test results directly from V570 thus eliminating the need for DataXport alltogether? Please Share your *.vlp and Excel format or pdf format required to josephtechcets(at)gmail(dot)com, Quote Link to comment Share on other sites More sharing options...
