2rlp Posted June 6, 2011 Report Share Posted June 6, 2011 Hi, I have to control the tension in a Web. We will be using a V130 + LC1 along with a Load cell. What would be the right way to go about this. Should I use a PID to control the the brake on the unwinder? Or is there another way of doing it. I will be using LC1 for the first time. Thanks, Ron Quote Link to comment Share on other sites More sharing options...
Damian Posted July 3, 2011 Report Share Posted July 3, 2011 Hi, I have to control the tension in a Web. We will be using a V130 + LC1 along with a Load cell. What would be the right way to go about this. Should I use a PID to control the the brake on the unwinder? Or is there another way of doing it. I will be using LC1 for the first time. Thanks, Ron Hi Ron, I assume you are using some type of 0-10v or 4-20mA to Pressure regulator to control the brake? PID control is the norm. You will probably end up leaving the D gain 0. You'll want to come up with some sort of scheme to adjust the response as the diameter winds down. D Quote Link to comment Share on other sites More sharing options...
2rlp Posted July 4, 2011 Author Report Share Posted July 4, 2011 Hi Ron, I assume you are using some type of 0-10v or 4-20mA to Pressure regulator to control the brake? PID control is the norm. You will probably end up leaving the D gain 0. You'll want to come up with some sort of scheme to adjust the response as the diameter winds down. D Hi Damian, Thanks for the reply. Yes I will be using a 4 - 20mA to regulate the powder clutch brake. i am not worried about the diameter as i am using a loadcell to check the actual tension in the web. this in turn modifies the brake condition. Ron Quote Link to comment Share on other sites More sharing options...
