Moran Posted December 6, 2019 Report Share Posted December 6, 2019 Hello i need to generate a square signal at 56khz 2.5v with the capability 50mA to the load can i use V200 PWM? is there another way to perform it? Thanks Moran Quote Link to comment Share on other sites More sharing options...
DanT Posted December 6, 2019 Report Share Posted December 6, 2019 HI; V200-18-E46B and V200-18-E62B have NPN Outputs rated at 100kHz HSO/PWM (others are only 50kHz NPN Out) Vision Models V350 and V430 with TRxx Have NPN outputs rated at 200kHz Max DanT Quote Link to comment Share on other sites More sharing options...
