I am working on a project that has a somewhat involved communication routine to read multiple values from an instrument.  This requires that I have several long messages in message composer that I am using to both request the data and also to parse the response.  I will need to use this technique in several different projects. Is there any way to export the messages from the message composer and then import them into a new project?  It takes several hours to manually rebuild these messages in each new project.
  • 7 months later...
