Vitaly Posted December 10, 2019 Report Share Posted December 10, 2019 Hello, I used the simple trend drawing function as is mentioned in the trend function block example. The curve runs from right to left, but the x axis was defined correctly.. Where's the problem? Thanks Vitaly Quote Link to comment Share on other sites More sharing options...
AlexUT Posted December 11, 2019 Report Share Posted December 11, 2019 Vitaly, There is no problem. Curve runs from right to left by design. Why do you think there is a problem? Quote Link to comment Share on other sites More sharing options...
Vitaly Posted December 11, 2019 Author Report Share Posted December 11, 2019 Hi, Thanks for your response. The curve runs from right to left. The time runs from left to right. When I stop the running and look at the graph, there is a discrepancy Quote Link to comment Share on other sites More sharing options...
AlexUT Posted December 11, 2019 Report Share Posted December 11, 2019 Vitaly, Publish picture with details here. Quote Link to comment Share on other sites More sharing options...
Vitaly Posted December 11, 2019 Author Report Share Posted December 11, 2019 Please see attached picture of display. I stopped the curve after 5 sec. How am I supposed to understand the the Y position regarding to the timeline ? thanks Quote Link to comment Share on other sites More sharing options...
AlexUT Posted December 11, 2019 Report Share Posted December 11, 2019 Until trend reach left side of frame, left side time is the Trend start time. Right side time is changing as it should be. It is not intended to see short trend. Let trend run until all Trend window will be occupied by trend. Then both, left side and right side time will reflect displayed time frame. Quote Link to comment Share on other sites More sharing options...
Vitaly Posted December 11, 2019 Author Report Share Posted December 11, 2019 thanks Quote Link to comment Share on other sites More sharing options...
