Koganei Posted December 11, 2019 Report Share Posted December 11, 2019 I would like to suggest that "Close Project" be added to UniLogic. An example scenario would be if I've been playing around inside a project but I don't want to save it, I can close the project, select not to save and then open another project, instead of having to exit UniLogic and then re-open it. Quote Link to comment Share on other sites More sharing options...
Swervomotor Posted December 17, 2019 Report Share Posted December 17, 2019 I would like to be able to open 2 projects at once on the same machine. It would also be nice to copy/paste ladder between the two.. But I would be good with just being able to compare side by side. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted December 17, 2019 MVP 2023 Report Share Posted December 17, 2019 Swervo is it not possible to run multiple instances of Unistream like you can for Visilogic? I don't know, haven't tried. No copy/paste, but you can see things side by side as much as you want. cheers, Aus http://forum.unitronics.com/topic/4015-multiple-connection-live-checking-tip/ Quote Link to comment Share on other sites More sharing options...
Saragani Posted December 18, 2019 Report Share Posted December 18, 2019 No, you cannot run 2 instances of UniLogic. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted December 18, 2019 MVP 2023 Report Share Posted December 18, 2019 OK. Swervo, don't forget my practice of printing to pdf, which then lets you easily have a view of another ladder structure for visual cues for actual assembly work. In Visi I often do this instead of running another instance, especially when only having a laptop screen to work with. cheers, Aus Quote Link to comment Share on other sites More sharing options...
Ness Posted December 19, 2019 Report Share Posted December 19, 2019 Thanks for the tip about printing to PDF! It looks like it displays twice the number of tag characters as the editor itself - I wish this was possible in the editor. I've tried installing UniLogic in a Linux VM with Wine and in Windows Sandbox. Sadly SQL Server doesn't work under either. Quote Link to comment Share on other sites More sharing options...
