Mr Singh Posted December 14, 2019 Report Share Posted December 14, 2019 Hello everyone, I'm having a problem with Vision V1040, Details are given below. 0 S. (Stop Mode - Fatal Error) Enum: Ox00000801 IP: Ox00348C18 00365C2C Ldr: Ox0000001C Desc: Undefined Opcode whenever our client is running motor, mostly this error is coming out, sometime PLC + HMI is running normally but mostly it ended up with this error, I think this error might be caused by noise of VFD, 0-10V signal to VFD is supplied by V200-18-E6B Snap In I/O module. so I want a solution for this, I can use signal isolator for 0-10V supplied from PLC to VFD to isolate the signal. but I wanna know if their is any solution can be done without using external components or devices. Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted December 15, 2019 MVP 2023 Report Share Posted December 15, 2019 V200-18-E6B offer isolated analog outputs but you must use separated power supply for this output or use VFD +24V power. Maybe this is useful for you. Plase find my link to pdf. Quote Link to comment Share on other sites More sharing options...
