jorge delgado Posted December 17, 2019 Report Share Posted December 17, 2019 Hi, i have a vision130 and recently download the latest version of visilogic but when i go to connection-communication & OS- get oplc information- check, at the end, it stops in step 2 but i dont if it has to be about the version of the visilogic or if i have to download a previous version. hope you can help me, thanks Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 18, 2019 MVP 2023 Report Share Posted December 18, 2019 Moved to the correct forum. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted December 18, 2019 MVP 2023 Report Share Posted December 18, 2019 1). Do you need to have the latest version and it's matching O/S upgrade? If not, stick with the version that matches the existing O/S. There is a often quoted saying here: "If it works don't fix it". 2). Sometimes incorrect installation will upset comms. Did you install the latest version using Right Click/ Run as Admin, and also set the visilogic.exe in Unitronics/ Unitronics Visilogic_C/ Main, as run as admin in compatiblity? If you didn't do this, uninstall, reboot and start again. 3). If you have a need for different versions of Visilogic running different O/S plcs, then this is what Version Swapper is for. http://forum.unitronics.com/topic/662-how-do-i-use-version-swapper/?do=findComment&comment=17317 cheers, Aus Quote Link to comment Share on other sites More sharing options...
