louisgermain6 Posted December 20, 2019 Report Share Posted December 20, 2019 Hey guys, I recently had to uninstall and reinstall Visilogic because when I had to change an operand value, the window was popped behind the main one and I couldn't do anything. But that is not the problem anymore. As the title says, the situation is that all of my coils and contacts are cables, I mean instead of seeing the NO contact I see a connection but it has the effect wanted (see screenshot). Does it happened to anyone and find the way to resolve it ? Visilogic version : 9.8.80 build 0 OS information : Windows 10 Pro Thanks for your help. Louis Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted December 20, 2019 MVP 2023 Report Share Posted December 20, 2019 Never had this, but have you tried Project/System Descriptions/Restore All System Descriptions? I don't think it will help in this case but try it first and report back. It does fix very odd behaviours with operand details not displaying correctly, but might cure this as well. cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 21, 2019 MVP 2023 Report Share Posted December 21, 2019 Does it occur with only one project or with every project you open? If every project, I would completely uninstall VisiLogic and try again. If only the single project, then I would send the project to Unitronics support to see if they can fix it. Quote Link to comment Share on other sites More sharing options...
louisgermain6 Posted January 7, 2020 Author Report Share Posted January 7, 2020 @Ausman I did try it as soon as I read your answer and it hasn't changed anything.. @Flex727 It happens with every project yes, and the curious thing is that it started to do this since I reinstall Visilogic the last time. Thanks you guys. Louis Quote Link to comment Share on other sites More sharing options...
louisgermain6 Posted January 7, 2020 Author Report Share Posted January 7, 2020 @Flex727 FYI I just performed another uninstall/reinstall of Visilogic and I still have the same problem. Maybe a version problem ? I'm using the last one 9.8.80 ? Cheers Louis Quote Link to comment Share on other sites More sharing options...
Kikis Posted January 7, 2020 Report Share Posted January 7, 2020 Hello, I bought a new laptop a few days ago and had the same problem for both U90 and Visilogic. I restarted my PC after installation and problem was solved for both software! Best Regards, Kikis 1 Quote Link to comment Share on other sites More sharing options...
louisgermain6 Posted January 7, 2020 Author Report Share Posted January 7, 2020 Thanks Kikis, It seems that it was the problem! You resolved it. Regards, Louis Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted January 8, 2020 MVP 2023 Report Share Posted January 8, 2020 The magic words full reboot solves a host of issues. It should be mandatory after any installation, and at least once a week or less. For me all my puters are turned off when I finish each night. (How much energy would that save the world if it was compulsory?!! I constantly see entire floors of buildings with everything sitting there still on, just to avoid that little delay each morning.) Don't forget W10 also does the Fast Startup feature by default, which I personally have disabled. Not many people know about this, it seems....they just like the quick start and think it's their wizzy system! A link thru quick googling: https://www.howtogeek.com/349114/shutting-down-doesnt-fully-shut-down-windows-10-but-restarting-it-does/ cheers, Aus Quote Link to comment Share on other sites More sharing options...
