Willo678 Posted December 26, 2019 Report Share Posted December 26, 2019 Hello everyone, My name is Dave Wilson, I own a small phone case company based in the UK. I have recently just invested into a new Sublimation machine that requires heat and vacuum pressure in order to create a personalise effect to one of our case types. I have purchased this machine and with no help from the supplier, struggled setting up and figuring out how to work the thing. All I do know is the machine is not heating up enough to complete the transfer process. To cut a long story short, I've been looking into this and realised it was programmed with a unitronics PLC. I need someone to help me figure out how to change temp control and vacuum pressure via the PLC? I have tried contacting the supplier several times with no avail. I understand you can insert a sd card to transfer the data table and adjust temps, when I do so it comes up with "password missing" and does not let me transfer any data except from hardware. I am a complete novice when it comes to this kind of thing and just need some help. I have navigated into system and seen the name Maurice as the programmer name. There is a Maurice118 on this forum which may just be a coincidence, but it would be nice to find out if it was him who programmed this machine. I'm thousands of pounds out of pocket and just need some help so I can feel like I havent been conned. Any help would be much appreciated. Kind Regards Dave Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 26, 2019 MVP 2023 Report Share Posted December 26, 2019 I presume you do not have the original software file (.vlp) that the PLC was programmed with? What is the PLC model? I'll tag @Maurice118 for you on the off chance he's the guy you're looking for. Quote Link to comment Share on other sites More sharing options...
Willo678 Posted December 26, 2019 Author Report Share Posted December 26, 2019 Hi Flex727, Thank you for your reply. No unfortunately not, i was not even given an instruction manual when purchased. The model is unitronics v350. I understand the programmer may have secured this with a password? correct me if I'm wrong, complete novice and have no programming experience. Thanks Dave Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 26, 2019 MVP 2023 Report Share Posted December 26, 2019 If you have VisiLogic installed, you can attempt to upload the project from the PLC. The chances are slim that you will be successful, as the programmer must take an extra step to allow that - the default is to not allow upload. Without the original .vlp file you may not be able to proceed further without some documentation. If you have some understanding of how the machine works and how it is wired, someone may be able to re-create the program for you. Hopefully I've overlooked something and someone will be able to chime in and offer some additional help. Quote Link to comment Share on other sites More sharing options...
Willo678 Posted December 26, 2019 Author Report Share Posted December 26, 2019 Hi Flex727, Thanks for the reply. That is a real shame. Would you be interested in taking on this project using visilogic and the current Unitronics v350 PLC? Kind regards Dave Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 26, 2019 MVP 2023 Report Share Posted December 26, 2019 I'll PM you. Quote Link to comment Share on other sites More sharing options...
i4 Automation Posted January 2, 2020 Report Share Posted January 2, 2020 On 12/26/2019 at 8:09 PM, Flex727 said: I'll PM you. Hi Dave, Are you making any progress? Does the PLC have an SD card in it? If you contact us (we are UK based) we might be able to get someone to have a look at your application. Just not to sure how quickly we can you some assistance as our customers (integrators) are only just returning to work. Andrew www.i4automation.co.uk 01480395256 Quote Link to comment Share on other sites More sharing options...
SRod Posted January 18, 2020 Report Share Posted January 18, 2020 I might be able to give a bit of support if that interest you.. Quote Link to comment Share on other sites More sharing options...
