Vision 130 without Network
Do I have to have the PLC connected to a  network to utilize?  The PLC will be used at a remote location without network access.  Was hoping to use the SD card option to retrieve results.  Using the PLC for testing purposes and need to get pressure readings after a run cycle.
Any help would be great.  New to the PLC world.
