T VARUL MOZHI Posted January 6, 2020 Report Share Posted January 6, 2020 Dear Sir/Madam, Kindly find the attachment for Two Festo Value with V700 plc in Modbus TCP IP Communication . V 700 IS A Master and as a Festo value Slave . Kindly modified and update the program. Thanks, Regards, T V ARUL MOZHI festo with v700 modbus TCP IP.vlp Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted January 7, 2020 MVP 2023 Report Share Posted January 7, 2020 18 hours ago, T VARUL MOZHI said: Kindly modified and update the program. What's wrong with it? Joe T. Quote Link to comment Share on other sites More sharing options...
T VARUL MOZHI Posted January 7, 2020 Author Report Share Posted January 7, 2020 Thanks for your replay. The same logic applied in the V1040 .It is communicating with 4 nos of FESTO Value with Modbus TCP IP. But in the V700 Modbus TCP IP Communication frequently not connected and in the Preset Holding function block Total Sessions & Acknowledgements number of counting not increasing. Thanks, Regards, T V ARUL MOZHI Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted January 9, 2020 MVP 2023 Report Share Posted January 9, 2020 The V700 has a different way of interfacing with Ethernet, as it has 8 sockets instead of the V1040's four. Open the Help and search for V700 - the first topic is how the Ethernet is different. You'll have to change how you monitor socket status. Take a look at this and let us know what questions you have. Joe T. Quote Link to comment Share on other sites More sharing options...
