MVP 2023 Ausman Posted January 9, 2020 MVP 2023 Report Share Posted January 9, 2020 Hi all, recently had to change some internal modules/configs in a 130. Pulling the PCB was far more difficult than I was used to, and made me stop and reassess. This was a 130 that was already in use, and I found that I had left the microSD card in place. This protrudes enough to not let the pcb glide past the normally easy gap. Removed the card and things were ok. Moral of the story......Always ensure the MicroSD is out of a unit before doing any internal work. I know this is a very limited scenario, as most times this access is done during first install, but felt it worth noting here. The same thing might apply to a host of other models. cheers, Aus Quote Link to comment Share on other sites More sharing options...
