Corey Posted January 17, 2020 Report Share Posted January 17, 2020 In UniDDE, if you right click on your open project or use the menu buttons, you can copy the Read Command, Stop PLC Macro, Run PLC Macro, and Run/Stop Toggle macro. If I have the read command in an Excel worksheet, it tries to start UniDDE.exe but fails. Instead, I had to clear the field until the workbook is open then add the read command =UniDDE|Items!'lblDDE(1)' to the cell afterwards. My second issue (the first being that I can't seem to get the UniDDE read command to automatically load the software) is that the PLC is not in Run mode. Therefore, I try to use the code that UniDDE provides with those copy buttons. If I use the "Run/Stop" toggle it will properly stop the PLC connection if it's already running. If I execute that code to make it run, it will run but Excel freezes until I click escape. I also tried the "Run PLC" macro, but it does absolutely nothing. My VBA to start the UniDDE software is below. Cell F1 = "C:\Program Files (x86)\Unitronics\Unitronics DDE Server\UniDDE.exe" Cell F2 = "UniDDE.exe" Cell F3 = "U:\Display Result and Write CSV.ude" Sub Load_UniDDE() Application.StatusBar = "loading PLC application" Dim strApp, strAppShort, strFile As String Dim WB As Workbook Set WB = ThisWorkbook strApp = WB.Worksheets(1).Range("F1").Value strAppShort = WB.Worksheets(1).Range("F2").Value strFile = WB.Worksheets(1).Range("F3").Value If strApp = "" Or strAppShort = "" Then Application.WindowState = xlMaximized WB.Worksheets(1).Range("F1").Select MsgBox "Please correct the software path and process in the Excel worksheet." Else If Dir(strFile) <> "" Then Dim objList As Object Set objList = GetObject("winmgmts:").ExecQuery("select * from win32_process where name='" & strAppShort & "'") ' determine if the DDE app is already running If objList.Count = 0 Then Shell strApp & " " & strFile, vbMinimizedFocus ' open the DDE app and project file End If Else Application.WindowState = xlMaximized WB.Worksheets(1).Range("F3").Select MsgBox "Please correct the project path in the Excel worksheet." End If End If Application.StatusBar = False End Sub UniDDE provides the following macros which are not working properly RUN PLC: Dim lchannelNumber As Long '/ Run PLC lchannelNumber = Application.DDEInitiate("UniDDE", "Items") Application.DDEExecute lchannelNumber, "Last Test Result_RUN" Application.DDETerminate lchannelNumber RUN/STOP Toggle: Dim lchannelNumber As Long '/ Run/stop UniDDE lchannelNumber = Application.DDEInitiate("UniDDE", "Items") Application.DDEExecute lchannelNumber, "UniDDE_RUN/STOP" Application.DDETerminate lchannelNumber Quote Link to comment Share on other sites More sharing options...
