Zoran Nikolic Posted January 19, 2020 Report Share Posted January 19, 2020 Hi, is there some simple solution for Samba 7 for counter. We need a counter in 00:00 format to display on screen but as large as can be Thanks Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted January 19, 2020 MVP 2023 Report Share Posted January 19, 2020 Maybe use images for animation is as large as can be for SAMBA 7 But you must make some ladder for image manipulation. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted January 19, 2020 MVP 2023 Report Share Posted January 19, 2020 Assuming the largest available font won't work for you, find or create 10 images for the digits 0 - 9 that are the size you want and use the "List of Images: By Pointer" HMI element. Quote Link to comment Share on other sites More sharing options...
Zoran Nikolic Posted January 19, 2020 Author Report Share Posted January 19, 2020 Thank you, I'll try that, we tried to max font but size 128 is'n enough. Images will solve the problem Quote Link to comment Share on other sites More sharing options...
