AleksanderØ Posted January 20, 2020 Report Share Posted January 20, 2020 I have a USP-070-B10 + USC-P-B10 I use for testing purposes, Last week I had to upgrade the firmware to be able to download the project I needed to test, so I do as many times before; grab the nearest USB-stick, format it FAT32, firmware manager, copy to DOK, insert, start upgrade etc. First thing should have seen as a warning was that the time to copy the files to the DOK took a looooong time. The firmware update took a long time, so I left the workplace for a lunchbreak, when I came back, it said something like "HMI OVERLOAD" or overflow, or something like that. So I removed the DOK and the power supply, counted to 10, and plugged the 24V back in. The screen popped up again with "SD-files unpacking" and "update is in progress" screens. I left it for some hours, and it never completed, or finished. So I figure that the USB-stick was at fault, made a new stick with the firmware manager, tried the "force_update" usb rescue thing, and no change. Left it over the weekend, came back today and it was still "update in progress" even if I start the panel without SD-card or USB stick, it still does the update in progress thing.. Is there any way to recover from this? Any suggestions are welcome Quote Link to comment Share on other sites More sharing options...
DanT Posted January 21, 2020 Report Share Posted January 21, 2020 Hi; Nearest USB Stick -- How big was it? Better be > 4GB !!!! Contact Unitronics Support to help you out -- Support@unitronicsplc.com or call them. DanT Quote Link to comment Share on other sites More sharing options...
AleksanderØ Posted January 21, 2020 Author Report Share Posted January 21, 2020 8GB kingston, I will try unitronics support, thanks Quote Link to comment Share on other sites More sharing options...
