jvalstar Posted January 22, 2020 Report Share Posted January 22, 2020 When I want to download my program I get the error: HMI - Localization configuration file - The Default Language is set to a language which is already defined in the project I added an extra language which is the same as the default, because I can't change the default language. How do I delete this error? Quote Link to comment Share on other sites More sharing options...
Ildar Posted November 18, 2023 Report Share Posted November 18, 2023 Update your Unilogic Software and PLC Firware to the latest version. This error will be gone. Quote Link to comment Share on other sites More sharing options...
Ildar Posted November 18, 2023 Report Share Posted November 18, 2023 Or if your deafault language is set to English and you add another language which is also English then you have this erro. Change the default language . Quote Link to comment Share on other sites More sharing options...
Saragani Posted November 20, 2023 Report Share Posted November 20, 2023 The default language is the fall back language, meaning that any text which is not translated is taken from it. You can edit the text on the HMI and Web when editing the elements themselves. Quote Link to comment Share on other sites More sharing options...
