cmarcus Posted June 14, 2011 Report Share Posted June 14, 2011 Has anyone else had problems with upgrading the OS that is packaged with Visilogic 9.2? I have several V130's that I'm trying to update. So far I've had 5 PLC's fail to take on the first try, 2 that I had to hold (i) and manually put the PLC back in to run mode and retry, and 1 that constantly fails on Step 1 (Erasing system files). I'm following the wizard, I'm plugged into COM1, I've got an windows XP based PC. Anyone have any ideas of what I could be doing wrong? Quote Link to comment Share on other sites More sharing options...
Jas Posted June 14, 2011 Report Share Posted June 14, 2011 Are you using the recommended maximum baud rate of 115,200? It will most likely fail with a slower transfer speed. Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted June 14, 2011 MVP 2014 Report Share Posted June 14, 2011 We had a reported problem with this last week. I haven't seen the PLC to try it myself. As Jas mentioned, baud rate is the first thing I would look at. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted June 15, 2011 MVP 2023 Report Share Posted June 15, 2011 Ditto. The older versions of Visilogic defaulted to 57600 baud. I've observed that when you install the new software version and start to upgrade the O/S, the PLC immediately goes to 115200 but the software stays at 57600 and doesn't bother retrying at 115200 unless you manually set it. It's bit me in the butt with my customers a couple of times. This may be an issue the Creators want to look at. Joe T. Quote Link to comment Share on other sites More sharing options...
cmarcus Posted June 17, 2011 Author Report Share Posted June 17, 2011 Thanks for the responses. I just figured it out. I did verify that I was at 115200, but that didn't seem to help. I had to cycle the power to the PLC, then use the advanced install. I also had to install the OS and boot strap files separately. After doing this the OS upgrades on all my PLC"s went smoothly. Thanks, -Chris Quote Link to comment Share on other sites More sharing options...
