Hello,
I'm using multiply formula and storing result into MF. I'm displaying results on display, and my problem is that result have 6 decimals, but I only need 1 or 2...
For better understanding, for example, I want to number 6.543210 display as 6.54 or 6.5.
By default, display settings when using MF are greyed out, and can't change decimal points (picture attached)...
Any suggestions, tips?
Thanks,
Petar
Hi,
MF cannot be formatted.
To show MF content in desired format, use Num To ASCII and format output string as you wish.
Then show this string on display.
B.R.
Stick with integer operands and multiply by 10 or 100 (prior to your calculations that would produce a decimal) then display with 1 or 2 decimal places.
I use this solution for correct display distance MF4  (mm)  in 0.1mm on display (ML4).  You can modify this for 0.01
MF1 = distance ( mm)    in FLOAT
  • Upvote 1
