Jas Posted June 14, 2011 Report Share Posted June 14, 2011 A step by step guide to performing a proper re-install of VisiLogic. VisiLogic Reinstall Instructions.pdf Quote Link to comment Share on other sites More sharing options...
KerryBecks Posted February 13, 2019 Report Share Posted February 13, 2019 Thank you very much! I'm just at this stage. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted July 11, 2020 MVP 2023 Report Share Posted July 11, 2020 I had a customer call recently trying to install Visilogic and was greeted with a "Catastrophic Failure" dialog box. Usually, a Catastrophic Failure means parts are flying out of the machine, something has caught fire, or your transmission in your car decides to delete the "mobile" part of your automobile. Windows 10 has brought us the joy of everything having to be done as Administrator. I've updated the Visilogic Reinstall instructions to include this necessary step. This is not built into the Visilogic install package, and I have it on good authority that this is difficult to do with the InstallShield version used for Visilogic. As far as the "Catastrophic Failure" is concerned, it is caused by the older InstallShield running into the Administrator wall. Fortunately, Support has fairly easy way to fix this. It is not Catastrophic. I have attached those instructions as well. Joe T. VisiLogic Reinstall Instructions 7.10.20.pdf Visilogic Catastrophic Failure.pdf 1 Quote Link to comment Share on other sites More sharing options...
pckoers Posted January 28, 2021 Report Share Posted January 28, 2021 We also experience problems re-installing Visilogic. Visilogic Unistallers Wizard deletes something critical from Windows. After Visilogic Unistaller has done his job my screen started flashing and Windows died. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted January 28, 2021 Report Share Posted January 28, 2021 You have to reboot in safe mode and delete from Registry vlp_auto_file entries. Reboot PC and repair VisiLogic installation.. Quote Link to comment Share on other sites More sharing options...
AustinNorth Posted October 4, 2021 Report Share Posted October 4, 2021 On 6/15/2011 at 12:02 AM, Jas said: A step by step guide to performing a proper re-install of VisiLogic. VisiLogic Reinstall Instructions.pdf 44.29 kB · 944 downloads Hi! I can't open the link. Can you suggest something else please? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted October 4, 2021 MVP 2023 Report Share Posted October 4, 2021 The link works for me using Chrome. I've had issues with some websites that only work with Microsoft products, so you might want to re-visit the Unitronics website from the Edge browser. If that doesn't work, contact Unitronics support at support@unitronics.com and they'll email you a copy. Joe T. Quote Link to comment Share on other sites More sharing options...
