Rog Posted February 18, 2020 Report Share Posted February 18, 2020 Was wondering if there is remote i/o outputs with 4 to 20 mA output. The URA-0004W and URA-0008W only shows 0 to 20 mA. Thanks Rog Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted February 18, 2020 MVP 2023 Report Share Posted February 18, 2020 Perhaps a distributor can answer your question directly, but you can easily create a 4-20mA output in ladder with the correct linearization settings. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted February 18, 2020 MVP 2023 Report Share Posted February 18, 2020 No, there are no analog outputs specific to 4-20 mA. You'll have to program the 4 mA offset. @Cara Bereck Levy - I dropped one of these modules in a test program and saw some dropdown boxes listed for each output in the configuration. Their function is not described in the manual - is there a more detailed document for these? Joe T. Quote Link to comment Share on other sites More sharing options...
