JMVittone Posted March 12, 2020 Report Share Posted March 12, 2020 I am trying to be able to set the Panel IP address of my US7-B10-RA28 via a ladder instruction. I want to store the IP address in a variable and load it upon startup. I can see in the "System.General" structs that there is a "Panel IP Address UINT32", but I cannot write to it with a store instruction. Any help is greatly appreciated!! Thank you..... JMV Quote Link to comment Share on other sites More sharing options...
schmorrison Posted March 19, 2020 Report Share Posted March 19, 2020 Personally, I would use the IP Settings Edit HMI elements under Numeric Elements in the HMI builder. You can set CPU/Panel IP & DNS Settings by using the element 3 times and changing its configuration in the properties window. I believe you can also set the IP in UniApps. I don't believe the UniLogic provides a means to programatically change the IP Address of the unit. They don't even have a DHCP client built in AFAIK. Quote Link to comment Share on other sites More sharing options...
JMVittone Posted March 20, 2020 Author Report Share Posted March 20, 2020 Thank you schmorrison! I was hoping not to have to do it that way, but I guess it's my only option... Quote Link to comment Share on other sites More sharing options...
