dierkens Posted March 18, 2020 Report Share Posted March 18, 2020 Does anyone have a good example of how to use the Radio Button object? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted March 18, 2020 MVP 2023 Report Share Posted March 18, 2020 I haven't had occasion to use this object, but looking at it, it seems pretty straightforward. Did you read the Help entry? A Radio Button object just presents a set of mutually exclusive items that the user can select. Only one of the items can be selected at a time. An integer register will contain the index number of the selected item. Besides the Help file, you can also hover your mouse over each item in the Properties Window for a tip on how to use each item. Put it in your program and play with it until you understand what's going on. Quote Link to comment Share on other sites More sharing options...
dierkens Posted March 18, 2020 Author Report Share Posted March 18, 2020 4 hours ago, Flex727 said: I haven't had occasion to use this object, but looking at it, it seems pretty straightforward. Did you read the Help entry? A Radio Button object just presents a set of mutually exclusive items that the user can select. Only one of the items can be selected at a time. An integer register will contain the index number of the selected item. Besides the Help file, you can also hover your mouse over each item in the Properties Window for a tip on how to use each item. Put it in your program and play with it until you understand what's going on. Yes. I've looked at all the documentation. Unfortunately I don't have a CPU/HMI that I can use to test anything I put together. Thanks. I'll just wing it until I get to the client site and can test out some options. Quote Link to comment Share on other sites More sharing options...
