CobryWZL Posted March 24, 2020 Report Share Posted March 24, 2020 Hi guys, we have connected our SAMBA to WLAN and can access it now through WLAN with the Visilogic software. Now we want to export data from the Samba through WLAN to a PC. For example when a new User enter his name on the touchpad of the samba, the samba should send this information to the PC. How can we do this? Is there any tutorial on a task like this? Greetings Quote Link to comment Share on other sites More sharing options...
AlexUT Posted March 24, 2020 Report Share Posted March 24, 2020 Hi CobryWZL, Requirement explanation is wery common. Please provide more detail: - What SAMBA model do you use? - What information PLC should send to PC? - How PC should know what to receive? - Is received information depends of user logged at PLC? More detailed request - more detailed answer. B.R. Quote Link to comment Share on other sites More sharing options...
CobryWZL Posted March 24, 2020 Author Report Share Posted March 24, 2020 Hi, I will try to specify my question: -We are using a SM43-J-T20 - There are several parameters ( %, Volume, operator name..) that needs to be entered in the touchpad of the SAMBA. This parameters are stored in the PLC as MB, MF or whatever suits. - all these information need to be send to the PC so another operator can see what is happening with the plc - it would be nice, if the PC could check the information cyclically and on certain events Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted March 24, 2020 MVP 2023 Report Share Posted March 24, 2020 Permanently run remote access or remote operator on the PC and tuck it away in a little used corner of the desktop? Or....have a look at UniDDE, or perhaps UniOPC https://unitronicsplc.com/Download/SoftwareUtilities/UniDDESetup_1_3_6.exe DDE will likely give you the basics of what you want, but you might need a little script running to cycle things periodically to fully achieve your needs. So you'd have a little excel window running and updating with just the info you want visible. cheers, Aus 2 Quote Link to comment Share on other sites More sharing options...
