Dragmast Posted April 4, 2020 Report Share Posted April 4, 2020 Hello, I am on my first steps to the PLC programming and just bought Samba SM35-J-T20. But I need a data cable to connect to my laptop via a USB. Please advise if the following cable will do the work: https://www.amazon.com/HDE-Interface-Console-Adapter-Routers/dp/B00HUZ6OMQ Best Regards to all :)) Quote Link to comment Share on other sites More sharing options...
AlexUT Posted April 4, 2020 Report Share Posted April 4, 2020 This set comprise 2 parts (and it is for Cisco Routers): 1. USB to Serial converter. 2. RS232 D-type to RJ45 8p8c). Unitronics use 6p4c or 6p6c connector. We recommend to contact PLC seller and obtain 2 cables: 1. USB to Serial Adapter (prolific chip based). 2. Serial cable and adapter (come in the kit RS232-CB1). RS232-CB1 include MJ10-22-CS25 (DB9 to RJ11 adapter) and 4 wires cross-crimped phone cable. Quote Link to comment Share on other sites More sharing options...
Dragmast Posted April 5, 2020 Author Report Share Posted April 5, 2020 AlexUT, Yes, I figured that out Thank you for the quick reply! I have already ordered the kit RS232-CB1. And a USB to serial adapter cable. Best Regards Quote Link to comment Share on other sites More sharing options...
